Aquabot rover yellow
Holbrookfaith
9
Lagrange, OH
Does anyone have this vacuum? If so, how do you pull it out if the water without the backflow screen opening and letting out debris? I assume at this point I have to pull the heavy vacuum out full of water level and not let the vaccum drain but it's easier said than done ... I'm finding it's not picking up dirt as well as it did when I first got it. It's only been used maybe 10 times...?
kimkats
46,309
Tallahassee, FL
Mine is not yellow it is blue. it works great and does not let stuff out of the slots. Did you make sure there is nothing in the pivot notches that is keep the flaps from closing all of the way?
