Aqua Rite Not Generating
tomlandry
1
lacombe,la.
Pool: 14000 Gal. Inground salt.
Problem: Not Generating. Had " T-15 Salt Cell" at pool store and is OK. Flow switch test OK. Current Limiter tested at board read 3.0 Ohms. At start: "off to auto" switch Leds: power-on, generating-on, No-flow "ON" then OFF after about (1) min.
Display Readings: Temp-92, cell voltage-30.8v, cell current-0.00, des output-99% (can change with knob). Inst. salt-0.0, AL-0, and
Rev-1.40 and salt at : 0.0 .After about 2.5 min. led Generating "OFF", Check cell "ON", Inspect cell "ON". Power led stays "ON". Display readings stay the same. Any help would be appreciated.
C0d3Sp4c3
115
NorCal
Most likely a bad solder joint. Remove the mainboard from the panel and inspect the K1/K2 relay solder. Add fresh solder 60/40 rosin-core.
