Aqua Rite Circuit Board - No Lights after Initial Start
tju22003
7
Anaheim, CA
I have an older Goldline Aqua Rite system. Model AQ-RITE, Circuit Board Part # 066012B-1, REV: B.
The system is not generating. The board lights come on when the pump starts then all lights go out. The LCD has readings. When in Spa mode the no flow light comes on.
Does that point to replacing he circuit board. Last year I replaced the thermistors
If so, is part number GLX-PCB-RITE the correct replacement?
Thanks
ajw22
25,667
Northern NJ
Pentair Intellichlor IC-60
Remove the board and look at the back for burnt solder areas. You probably have bad solder areas around the relays. You can try touching them up.
More info in...
ajw22
25,667
Northern NJ
Post pics of the front and back of the board.
JamesW
25,002
Try touching up the solder on the thermistor legs.
Reinstall everything and check and report all diagnostics.
Diagnostics are all 0000 except for salt reading of 2600.
That seems unlikely.
Are you sure that every single reading was 000?
tju22003
7
Anaheim, CA
Update, when taking the photos i noticed the bad soldering job on the Thermistor. I re-soldered and now have power and generating lights! Look like the loose Thermistor was the issue
Reactions: JamesW
