system consistently reads 600 to 800 ppm below confirmed actual
Also, when I reset instant reading & countdown then settles. The (-) is consistently 1/2 or less of the (+) reading as follows;
also note big difference in amperes, these should be the same Values just reverse.
a) -27.2v. -3.9amp 88F 1200ppm
b) +25.7v. +6.37amp 88F 2600ppm
c) actual same sample same time as above , meter 3686ppm , chemical test 3400, pool store 3300
this is current info but this issue has been going on since the install in 2018, multiple warranty visits, just replace cell but the low readings never is fixed. I added as much a salt as possible without going over 3400ppm actual to try and push the system reading up.
is it a cell issue , a board or transformer?
SYSTEM DETAILS
Hayward-gold line Aqua-plus (PL-Plus 2018 serial# 3L17058-1005922) ( board pn # G1-011049f. Software Ver 4.46)
hayward turbo-cell GLX-cell 15 W (install 8-2020 new serial# 1E20198-400705 pn# G1-929026A-revC) (this is the third new cell since 2018) ( cleaned just prior to the above readings, and cleaned every 3 months)
15,500 is gal inground plaster pool. overall chemistry is properly balanced and checked
SYSTEM DETAILS
