Aqua link Spa/Pool Temps Mixed-up
dielseman
133
GA
Hi there, I recently turned off the circuit breaker for the Aqualunk for 5-10 mins. Since then, the control panel has been reporting the spa temperature as pool temperature. The panel still reports spa as spa though.
Additionally, a pump was recently repaired and the tech made some changes to the actuator. I’m not sure if this has something to do with a change to the acuators or something else.
ajw22
23,657
Northern NJ
Pentair Intellichlor IC-60
It is not clear what panels you are talking about.
Do you have an All Button control panel or a One Touch control panel.
Which control panel?
What does this mean?
Post come pics of what you are seeing.
dielseman
133
GA
Here are some pics. Suddenly the Aqualink is reporting the Spa temp, as Pool.
ajw22
23,657
Northern NJ
In the pics you posted you are in POOL mode and it is reporting pool temperature.
Press the SPA button to change to SPA mode and report what happens. The red LED by the SPA button should turn on.
dielseman
133
GA
Yes, if I turn on Spa button, the lights turn on. However, something got changed up with the temps for the filter/freeze protection. I'm not sure how to adjust this. Right now, the Aqualink is reading the Spa temp as Pool temp. It also reads Spa as Spa.
ajw22
23,657
Northern NJ
There is only one water temperature sensor.
When in POOL mode the water flowing past the sensor is from the pool and will show the pool temperature. When in SPA mode the the water flowing past the sensor is from the spa and will show the pool temperature.
When switching from spa to pool you need to give the sensor time as the water temperature changes.
Post pics of your equipment pad showing where your water temperature is placed.
Post pics of your display in pool and spa mode.
