Aqua link RS 2.0 Spillover / LowSpeed
USATUS102
1
I have a Pool Spa Combination with a Aqualink RS 2.0 system to control in-floor cleaning system spillover and a 2 speed Pentair whisper flow pump and solar. What I’m trying to accomplish is have the pump operate on low-speed with spillover. The #3 dips switch is on to activate spillover (aux3 controls the JVA that’s activates spillover). When spillover is on low speed is prohibited. I moved the #3 dip switch to off and assigned the aux to spillway. Spillway actives the #3 aux but the JVA does not rotate I wa attempting to operate the JVA under a different name that would not be prohibited. It appears that I need spillover activated to cause that JVA to move when spillover is activated and off when floor system is turned on. I want to tap into the low speed for energy savings and keep the spill over on. Anyone tackle this issue.
PoolGate
4,092
Damascus, MD
Have you tried creating a macro command to accomplish this? It sounds like you might be using a macro now usually each function is independent. Is your low speed relay connected into the same aux as the spillway JVA? If so, you may need to rewire some things.
