Any structural engineers?
butchcassidy
16
Central TX
First off, I hope this is in right area, please move if not.
Pool and patio were just installed this month, now I'm looking into options for the circled pillar. I would love to remove it, but just don't know if it is load bearing. Any ideas by looking at these photos?
tim5055
11,188
Franklin, NC
I’ m goINV to guess that it’s about a 99% chance it’s load bearing.
Hard to tell the headroom there, but if you have height to spare you could span that with a beam. Almost anything can be done with a fistful of $100 bills....
Jimrahbe
23,474
Bedford, TX
Butch,
There would be no reason to put it there if it were not structural, as it would look better without it..
Their choice was an expensive beam or a cheap post.. :mrgreen:
mguzzy
I'm going to vote load bearing. all the posts seem equidistant from each other and the walls, so the beams between them are the same. Try removing the trim at the top of the bricks. I bet you'll find the bricks are set around a square post (4x4 ) and you might see the bracket that ties the post into the beam. If that beam is continuous then it depends on how big it is. ie, 4x10, 4x12, etc
SpringPool
530
San Antonio TX
It also depends on which way the joists run. More than likely they point towards the pool which means that edge is load bearing. If for some reason they run the opposite way it won’t be load bearing but could be where they butted to beams together
