I have an Intex pool, 15' X 48". This is my second winter with it. Last winter I plugged the inlets and removed the pump, used the pillow and got a decent cover. In spring water level was fine and just had to balance chemicals. I don't recall having to add any water but maybe a little. This year someone told me I should drain water below inlets so I did that and again pillow and cover. I'm in Chicago area so the water in pool has been pretty much a block of ice and snow all around the pool. A few weeks ago we had a nice day and I ventured out by pool and noticed the water level has dropped by about 4" below the inlets. I assumed there was a leak and thoroughly examined the exterior of the pool to determine where it was coming from and don't see anything. Assumed it was under the pool and I'd spend the rest of the time until opening seeing the water level continue to drop and end up with an empty pool. But the water isn't dropping any more. Every few days I go outside and peek under cover and it's still about 4" down. Is it normal to lose water over winter?
