Hello, I had an issue with my sand filter and my spider gasket 1 month ago. I figured it out and changed it, only the gasket (was a pain to remove because glued). After one month, same issue, water going through the waste outlet after a backwash.
I opened the head of the filter and found the spider gasket completely damaged (see my picture)
So what could cause that? Heat? Chlorine? (I went through a slam process during the last month) or just bad quality one?
Thank you for your opinion.
