Antifreeze in Pool
GrandizerGo
64
Ontario, Canada
Fiberglass
I have antifreeze (pink jug) that got in the pool from the skimmer box. I won't be opening the pool for another month. Do I need to drain or partial drain to dilute? I can smell the antifreeze when I lift the cover. Help?
In almost all cases, antifreeze from the previous winter entering the pool's water is not a problem. Curious though, it would be good to know the details for your pool. Would you update your signature please with all of your pool and equipment info. Also, when you do open, keep the cover off for while as you allow the sun's UV's to oxidize the chemicals and organic matter the chlorine will be eliminating.
