New member, first post. Glad to be here.
I will try to provide as much background as possible for everyone.
Pool is 14k gallon, Pebbletec, Hayward components/Aquarite salt system, VS pump running high for 5 hours then low for 8 hours, in floor cleaning, cyclone pre-filter (I will add all my pool info to my signature)
I consider myself fairly competent in electrical and maintaining my own pool. Some backstory, chemistry is generally always in check with the exception of calcium given our ridiculously hard water where I am at. This includes salt level which is currently 3800 tested by Taylor drop kit.
We have gone through I believe 4-5 salt cells within the 8 years of owning the pool. I just contributed it to the cost of salt pools. Apparently, these should last 5-7 years. 2 SWGs were Hayward and the rest were generic brands which typically get great reviews. Current SWG, Blue Works T15 is on its way out again, only reading 1900 salt and not generating. This cell is only 14 months old.
I have previously checked everything including the thermistor on the Hayward board. I even bought a new board and replaced mine to no avail so put the old board back in and kept the new board for the future. There are no typical tell tail signs of anything on the board itself causing issues from what I've read here and online through troubleshooting the board.
The ONLY thing I can think of which is killing my SWGs I just read yesterday the pump and salt system should be on dedicated power feeds. Well, mine is not, power comes into the Aquarite box which pigtails to the board then continues onto the pump. Do you think any spikes from the pump turning on could be killing the cells? Is there enough safety built into the board to prevent that? I'm tempted to just pull a dedicated feed for the pump and see what happens.
When the salt cells are new there are no issues whatsoever, they just do not last. Current cell is a Blue Works T15 which is only 14 months old and failing as mentioned above. As I read here, I changed the Aquarite system to a T5 and now it is reading a salt level of 3100 and generating without issue.
Cell is always routinely cleaned with MA. I was originally using a 4:1 ratio of water/MA but read that can impact plate life so I started doing even less MA yet the cells still don't last. I read on here that a cleaning vinegar can be used as well so I'm going to move to that as well.
Also read that the SWG should be mounted vertically with VS pumps, is that something I should do? It's horizontal and I keep the belly of it towards the ground so the plates are hopefully covered while the pump is in low mode.
Here's system info while pump is running:
4200
91
26.6
5.76
45P
-4300
AL-0
r1.59
T-5 (cell is actually a T15)
Sorry for the ridiculous long post and info. I'm literally at a loss at this point. My wife wants me to just convert the pool to normal chlorine tablets, but I really don't want to at this point. Any help or suggestions is greatly appreciated. Thanks!
4200
91
26.6
5.76
45P
-4300
AL-0
r1.59
