Another Hayward Ecostar 3400SVP pump Drive Error
PaulB33
4
MA
Hi,
I looked up the Pump Drive Error for the SP3400VSP and found references to contact @hayward directly if we are having the pump drive failure problem. I bought the pump in 2012, had it repaired in 2014, and now I am getting the dreaded pump drive failure message. I was looking for some guidance and hope that I can rectify quickly to complete the closing of the pool here in MA.
Thanks for the help and guidance!
Paul
tstex
1,796
Houston, TX
Paul
If you've had that pump since 2012 and it just recently worked, count your blessings. I would not spend a dime on it and put all funds to a new pump.
I cannot see if you have automation or not, but if you do not, I'd go w the Pentair Inteliflo. If you do have automation, plz post back.
ajw22
18,169
Northern NJ
Hi,
Paul
Some folks have replaced the motor with a SS or DS motor and in effect converted the pump to a TriStar pump. Read...
jimmythegreek
In The Industry
Aug 10, 2017
2,501
Morris Cnty NJ
The newer models are pretty good I have one on my personal pool. The pre 2016ish have the drive issues. New drive is 500ish depending but as said the tristar is almost same pump if you replace and need to stay Hayward go that route. The hookups are exactly the same only the address in automation panel is different if that's what you have. Simple push pull job
danchronis
1
CA
Hi,
Paul
Same drive problem as everyone else. Did you repair or replace?
