And away we go!!! Started conversion tonight. Lots of PIPs
TBWB
Active member
Jun 23, 2010
39
Two 180 oz jugs into the process and the pool is a nice shade of lime green/ baby poo yellow.
We also got these scummy looking bubbles whenever we pour in a jug but they disappear in just a few minutes.
Ordered my TF-100XL test kit from Dave and it's on a Fedex truck as we speak. :party: I'm using my OTO Walmart test kit in the mean time but it won't help me much until Friday when the other test arrives.
Here's my question for now-- my husband bought Clorox pro results outdoor bleach cleaner for our first day.
Is this going to do us any harm? I cannot see anywhere on the label or the website what percentage of sodium hypochlorite is in a bottle. Here is the site for it: http://www.clorox.com/products/overview ... od_id=cobc
It does contain a thickening agent as well as surfactants. Will this hurt our progress? He bought 6 180 ounce jugs of the stuff. On the next trip to Walmart (and I'm sure there will be many) we will be sure to get the regular Great Value bleach with no extras.
TBWB
Active member
Jun 23, 2010
39
Oh and two more quick questions--
Should we just leave the filter running 24/7 during the conversion?
Can we still use the Polaris to vacuum up debris during the conversion or should we remove him altogether through the whole process?
JasonLion
Platinum Supporter
I would avoid the outdoor version of clorox. It doesn't list it's ingredients, has thickening agents, "protectant for metal surfaces" (whatever that is), and kind of implies that it has some detergent.
You should leave the pump/filter running 24/7.
You should remove the pool cleaner until after you have added CYA (near the end).
TBWB
Active member
Jun 23, 2010
39
Here is a lovely night shot as of 10:00 pm tonight. It's like looking off the end of a pier at the river. :shock:
Off to buy more bleach first thing in the morning!
Thanks for the input Jason. I'm sure I'll have many more questions.
TBWB
Active member
Jun 23, 2010
39
Thursday July 1 : 10:00 am--
Just got back from the pool store with a reading on our levels:
Baqua- 0
Chlorine- 0
PH 7.8
Calcium Hardness- 177
Alkalinity- 52 (they rec. 4 lbs alkalinity to be added)
And here is a pic after three more jugs of 180 oz bleach were added this morning.
My steps look better after a good scrubbing last night. The pink algae is gone, but I think it just turned brown and drifted out into the middle.
I just picked up 27 gallons of bleach at Walmart this morning. I think I got approximately 6 comments from folks saying, "Somebody is gonna do some cleaning!" :-D It took a lot for me not to say "Here's your sign." Instead I just said, "Do they sell HazMat suits at Walmart?" LOL :eek:
I'm off work from now until Tuesday so we plan to hit it hard over the weekend around the clock and try to keep it at shock level. I'm really looking forward to getting my test kit so I can have more accurate numbers. According to the pool calculator my pool needs 4.6 jugs to get from 0 to 15. For now should I just be adding about 4 gallons every few hours or so? What has been your experience to get the level raised up?
TBWB
Active member
Jun 23, 2010
39
Should I add baking soda to raise the alkalinity or just not worry about it for now? Since our PH level is ok but on the high side I don't want to add the baking soda and raise the PH up.
What do you guys think?
JasonLion
Platinum Supporter
Your TA is a little low, but not a problem for now. However, you should lower the PH to between 7.2 and 7.4. Adjust the PH when the FC level is zero, give it an hour to mix in and then test the PH again to be sure you are in that range, then go back to adding chlorine.
TBWB
Active member
Jun 23, 2010
39
Here's a true rookie question: Where can I get muriatic acid? Is that a pool supply only thing or a Walmart thing? :)
TBWB
Active member
Jun 23, 2010
39
Here is a pic as of 4:30 this afternoon. It was the first time I've added chemicals and not seen any type of reaction (aka yellow plume of yuckiness) in the water. I take this as a sign of making progress. We've also lost a lot of the green and it's gone more to a milky blue color. :goodjob:
svenpup
835
Sacramento, CA
It's a pool store thing and a hardware store thing (paint aisle or pool aisle). Walmart won't have it. Get the 31.45% stuff if you can cause you pay the same price per gallon for the weaker stuff. Just like the bleach, you want the plain stuff. Don't get the low fuming or "safe" stuff as they add stuff you don't want.
TBWB
Active member
Jun 23, 2010
39
Thanks Sven! That's the stuff that cleans concrete, right? I'll get my husband to head to Lowes or HD and see if he can find some tonight.
Butterfly
10,045
South Carolina
You are making great progress. Nice pictorial, too.
You are really entertaining some of us! :-D
I just picked up 27 gallons of bleach at Walmart this morning. I think I got approximately 6 comments from folks saying, "Somebody is gonna do some cleaning!" It took a lot for me not to say "Here's your sign." Instead I just said, "Do they sell HazMat suits at Walmart?" LOL :eek:
LOL :lol: :lol: :lol:
TBWB
Active member
Jun 23, 2010
39
The Test kit came!! :party:
Here are my first readings:
FC: .5
CC: 3
PH: 7.5
CH: 230
CYA: n/a (I did the test just because I was excited to try them all out but I could still see the black dot all the way to the top.)
Here is the pool as of noon today.
Look! We can see the bottom again in the shallow end! This is great news! :mrgreen:
It's already looking SO much clearer. I'm gonna get the PH down to 7.2ish and then get my FC levels back up this evening and overnight.
Any other advice at this point?
TBWB
Active member
Jun 23, 2010
39
6:00 pm Friday July 2 levels
FC: 13
CC: 3
PH: 7.4
Photo from this evening, not much change from this morning:
And just as a guideline here is what and FC of 13 looks like on an OTO test kit, in case anyone is starting out with just that kit like I did! Look how orange that is!
TBWB
Active member
Jun 23, 2010
39
Much better than 2 nights ago. We can barely make out the pool drain now, which is something we've never seen from above water before.
Checking FC levels every few hours tonight, and they seem to dip down to about 10-13 within a few hours after raising to 15.
Kias
664
NW Ohio
I just love watching these conversions!
On a side note, I get muriatic acid from our walmart. They keep it in the hardware section. Your mileage may vary...
Sent from my Droid
TBWB
Active member
Jun 23, 2010
39
Folks, I believe we are very close to achieving clear pool status!
Levels at 8:30 (overnight):
FC: 7.5
CC: 3
Got the FC up to 15 and here are the levels at 10:30:
FC: 12.5
CC: 2.5
I'm hoping to keep it stable all day today and see how it goes tonight! :goodjob:
