I have absolutely no experience installing AGPs. So, when my wife suggested it, I accepted the challenge to install a standard 27' round AGP. The bottom rail and upright base are plastic. The uprights and wall are steel. I think I'm ready to install the wall, but I'd like to check with you all before proceeding.
I used a BobCat skid steer and a water level to level the ground to 2-1/2" between the low and high points. I measured and marked the wall location and then laid the bottom rails and upright bases to locate 8x16 pavers that will support the uprights. The level of the installed pavers measures 1/4" between the low and high. Lastly, I used a cutter mattock to level the ground between the pavers. Because the low paver (the first one installed) measures 1/2" below the adjacent ground floor the pavers and the ground between them form a kind of track where the pool wall will be. I plan to level the ground on the outside of the wall to provide the full wall height (52") from grade. This should enable me to avoid questions about a fence.
I've got 3-1/2 yards of sand ready to spread. With a wall diameter of 26'-10" that amounts to a 2" layer of sand.
I took several measurements of the ground floor and found the high point (+ 2-1/2") is one small area (~ 15 SQFT). Because most of the remaining area is level to within +/- 3/4", I figure, after spreading the sand, the high area will be covered by 1/2" of sand.
The attached photos show the bottom rail and upright bases and its "track"; pavers and the location of the bottom rails.
Am I ready to proceed with the wall installation?
