Am I On the Right Path?
slimb2061
21
Dothan, AL
New pool, tested about 9:30 p.m. after day of full sun with temperatures at about 90 degrees today. Am I on the right path so far?
pH: 7.8
FC: 4.0
CC: 0.0
TA: 140
CYA: 80
splashpad
2,708
SE Kansas!
pH: 7.8
FC: 4.0
CC: 0.0
TA: 140
CYA: 80
Agree with wobberlori :)
If you "need" something to do with your pool, I would bring the PH down to 7.4. Otherwise, it does look good :) As long as your FC is the same or higher in the morning (before sun on pool), you should be ok. The CYA is slightly high, but if the pool is in full sun, it might be needed!
Reactions: slimb2061
slimb2061
21
Dothan, AL
Yes, we use a SWG. That FC of 4 is at the end of day just before SWG comes on, and the FC is higher in the morning and throughout the day. The pool is in full sun from about 6:30-7:00 am until 7:00-7:30 pm.
I have some muriatic acid that have been adding in small amounts, but the prior two days were heavy rains throughout both days. So expected to see pH in higher 7s.
Thanks.
Reactions: splashpad
