Good evening, I'm a new pool owner and just finished pool school with the builder. I have been reading this forum for the last 6 months trying to learn as much as I can. The builder built and really nice pool but the instructions for pool care when it's done is not very good. Pool has been full for more than two weeks and was told to put salt in it in 21 days. I asked multi times about chemical levels and keeping them correct, was told just to brush until pool school, and told me to keep chlorine tabs in the skimmer.I have been checking with my t-100 test kit. I keep reading that my ph levels should be climbing but they have stayed between 7.5 and 7.8 since it has been filled. I continued to use the tabs to slowly raise the cya. I am switching to salt on sat and want to make sure all is good before the switch. Any suggestions on adjustments. I do have tree water falls and two bubblers, which I don't run very often.
Water temp is 70 degrees
Fc. 6
CC. .5
TA. 100
PH. 7.8
CH. 225
CYA. 40
Fc. 6
CC. .5
TA. 100
PH. 7.8
CH. 225
CYA. 40
