Am I being too picky???
Kimber_D
23
Austin, TX
The lines on my pool are off. The back from the right to the left comes in and is not exactly straight. It all comes in on the left. Will it look better once it’s completely finished? Will it be less noticeable? Is this common? Do you see it or is it just me? Can anything be done at this point or am I stuck with a crooked pool?
ajw22
21,287
Northern NJ
Pentair Intellichlor IC-60
Did you measure various distances along the walls to see if they are parallel the way you expect? The eye if often deceiving in judging lines.
What did your pool plans show?
Kimber_D
23
Austin, TX
I kinda see it but I dont know what the end plan looks like. Gunite is rough, when finish material goes on it will totally change from what it is now
Ok, the concrete owner is the one that told me it wasn’t square. The pb came the next day and fixed the spa but I’m not sure fixed the rest of it. I guess I will wait and see what it looks like when it’s done. Thank you! This is our first time building a pool so not sure what to expect.
Kimber_D
23
Austin, TX
No, I haven’t. I just know the concrete owner came out and said it wasn’t square. He did the measurements before the concrete. The pb came and definitely fixed the spa. I just don’t think it matches all the way to the other end. The spa comes in at the front as well. The measurements were all right, it was just all done at an angle if that makes sense? The pool is tilted down. I guess I will see what it looks like when it’s all finished.
ajw22
21,287
Northern NJ
If you do not like it then speak to the PB. Waiting until it is all done will leave you with little recourse.
Reactions: Woodstock1234
Kimber_D
23
Austin, TX
I didn’t, the concrete guy measured everything and said it wasn’t square. He was scheduled for the next morning. The pb came out and squared off the spa but nothing else so the lines are still off. At this point, is there anything I can do but just live with it being crooked? Look at the sun shelf, you can visibly see that it’s not square.
jimmythegreek
In The Industry
Aug 10, 2017
3,088
Morris Cnty NJ
Do you have a drawing of end results? Most pools are not perfectly square they vary slightly. The coping is what matters on install amd will give you the final look, nobody sees a slight variation on overhangs, and the plaster is usually built up to meet evenly. How far out of square are we talking about?
Kimber_D
23
Austin, TX
Thanks everyone! I did measure and it is off on the pool shelf. I took another picture from my porch with my back to the wall with the pool spa directly in front of me so you can see more of what I am talking about. You can see that the spa is square and the shelf is not. I hope there is something they can do. My pb will be here later this week. We told him we didn't want more work done until he was able to see what we are seeing. In your experience, can this be fixed?
Jimmie48
141
Frisco, TX
A tape measure never lies....when your PB is there get one out and show him if its truly off they will fix it. I will say though the coping will really frame it so if there is just a little bit off on the gunite the coping will help to dissuade the eyes away from it and the plaster will fill in the gap. Good luck this looks like a cool design!
Randrx2
374
Orlando, FL
I like to see the "Am I being too picky" posts. My answer is almost always no you are not! You are spending a ton of money and they need to get it right.
I did not see it in the first picture, but can see it now after seeing the second picture.
I am assuming that the hot tub and shelf need to rotate up clockwise so that the sunshelf is square.
If it is not per plans, they need to fix it.
It is much easier to fix now, even though it is still a lot of work. If you can see now and do not get it fixed, you will see it everytime you look at your pool. Good luck!
Screen Shot 2020-09-28 at 12.17.16 PM.png it
sktn77a
1,953
Chapel Hill, NC
It's a little hard to tell from your picture, but if that's the worst of it, search this site for some real horror stories. That might put your situation into perspective.
Kimber_D
23
Austin, TX
Ok, I have a picture of what the pool actually looks like. The pb said if we cut off the spa and sun shelf which to me would make it look less off that we would hurt the integrity of the pool. So it sounds like I have to live with this. What are your thoughts? We are not happy!
Newdude
4,847
NY
Hey Kimber !! I had the exact opposite problem. My pool was dead square/plum/level but the 4 corners of the patio had different slopes going away from them so the whole thing looked twisted. It did not help one bit that my brain knew it was an illusion, it bothered me daily.
The good news is you will be able to stage furniture, planters, deck boxes, decor, etc to take the eyes off the noticeable areas. It’s trial and error so it may take a few tries to balance something that hides what needs hiding while looking like it belongs in that spot.
I am also of the mind that you paid darn good hard earned money and deserve what you paid for. You’d never accept a brand new Cadillac with a smashed up hood. This is no different but some people don’t want the added time, aggravation and upfront expense of lawyers to fight it. Either fight it or make them reduce the price enough that you will feel great hiding the problem areas.
Kimber_D
23
Austin, TX
Thanks, what was the outcome of your pool? Do you have a before and after picture?
Kimber_D
23
Austin, TX
The highlighted green is how the pool was actually made. I asked if he could just cut off the sun shelf and spa and the pb said it would hurt the integrity of the pool. Not sure what to do. I really hate looking at it.
