After almost 2 months of waiting, we have this for a starting point. Plan was to start this afternoon. However we had quite a rainstorm this morning. I will update equipment later
Not the way you like to see a project start. But it's good you caught it when you did. They definately need to make it right. I doubt they will want to pull the shell and replace, but you never know. FB is quite durable, so a repair/patching job might be recommended although a bit noticable. At least in the spa the water weight isn't as much as if the crack was in the pool deep end or something. Still, curious to see how it turns out.Begin to fill with water and I discovered a crack in the fiberglass in the spa seat.
yes, ricardo and lalo.Good luck, who is doing the Install Ricardo and Lalo?
Let me know the outcome of the crack issue.
John
