I’ve been trying to get our pool together despite a fractured knee. It’s just me and my 11 year olds. I had someone open and clean it. I’m not sure how good of a job they did. I was hospitalized and the pool sat there, accumulating pollen, leaves. It’s a mess, I’ve vacuumed a lot up with an automatic vacuum. I test by having someone come get it and test it at their store. It’s PH up, then PH down. Add this that and the other. Then I had no stabilizer and was told to put an entire bottle in (instructions were in writing). I did, tested myself with my TFP tester, CYN was 200! From reading here it means drain (at least half) and refill. To kill two birds with one stone, I was trying to vacuum (to waste) get the dirt and water, but having problems getting it vacuumed. Hose won’t work as I have to vacuum up hill. We tried the hold it and throw over the pool to get it started until the ground was so wet, my crutches were sinking.
Can you connect the vacuum hose to the skimmer on the pump and vacuum to waste with water below skimmer)? If so, how?
Can you drain a pool using your pump?
What other recommendations?
PH 7.0. Chlorine null (law doesn’t allow disposal of chlorinated pool water on the ground).
I planned on switching to chlorine and the TFP method as soon as I am more mobile. Thank You!
