Alkalinity level at 70 in Salt pool....ok?
mihzyd777
283
Manteca, CA
Pentair Intellichlor IC-40
I'm using the Troublefree pool app. I just want to be sure I'm using it correctly...pool is Salt water and when I check Alkalinity it is at 70 and pH at 8.2, chlorine at 2ppm. So the only thing I should have to add is Muriatic acid to lower pH correct? The app says add 1 cup for the size pool I'm checking. The Alkalinity is perfect at 70 since it's a SWG pool is that correct?
Thanks!!
jseyfert3
1,577
Southern WI
Yes, 70 is good.
That said, TFP recommended alkalinity is not related to the use or non-use of a SWCG. If you take a look at the recommended levels page you'll see that the recommended range of TA doesn't vary SWCG to liquid chlorine, or vinyl pool to plaster. The app also lists recommended ranges if you've entered your pool type appropriately.
wireform
In The Industry
Aug 15, 2017
2,288
Spring Valley, NY
Well the PH is high and MA will take care of that. Your FC is very low and should be brought immediately with liquid chlorine to target levels. The SWCG will only raise it marginally once your at your target but by design it's not going to bring it up fast enough to avoid an algae bloom.
Jimrahbe
21,782
Bedford, TX
777,
What is your CYA??? The minimum FC is 3, so from my point of view your FC is way too low..
The idea is to try and keep your FC at your target or higher.. In my mind it does not make sense to try and keep your FC between your target and the minimum.. All it takes is one bright sunny day and boom, there goes your minimum.. There is zero downside to running your FC a little hot, and a large downside to running too low.
As far as TA goes, you should ignore it unless it tries to drop below 50 ppm.. Just worry about keeping your pH at about 7.6 to 7.9...
There are two sections to the CYA/FC chart.. Standard pool and Saltwater pools... FC/CYA Chart
mihzyd777
283
Manteca, CA
Thank you all very much. Should I drop the pH a little lower say 7.4 since I do have a salt pool and a waterfall that I run which raises pH right? I do have to check CYA levels still
wireform
In The Industry
Aug 15, 2017
2,288
Spring Valley, NY
Thanks!!
How are you testing? Give us your complete tested levels to see if there's something we can correct.
mihzyd777
283
Manteca, CA
Using the drop tester kit. I have a Taylor kit too that I tested cya and it showed 50? But I may take it to Leslie Pool to have them confirm.
So here are levels:
Ph : now 7.8
Cya: 50
Alkalinity: 70-80
Chlorine: 2 - 2.5
Anything else I should check?Water temp 78
