Hi Everyone,
Before I went away on holiday for a month (so no activity) I did the following:
Large dose of shock FC 30ppm, and had PH 7.4 & Alkalinity 85ppm balanced then. Good I think.....
Tested my pool last weekend when I came back, and pool was clear to my amazement (no algae)
FC 16ppm, PH 7 & Alkalinity 100ppm, I increased the PH using ph+ which brought my PH back to 7.4 which is good, but my alkalinity is now 110ppm approx.
According to the gov. pool guide for my area the max alkalinity allowed is 120ppm.
I'm concerned if my PH drops again our starts to go out control i'll have to put more PH+ thus raising the alkalinity again.
I guess a few questions arise:
Is there a danger to human health or equipment with high alkalinity?
Is there a way to lower alkalinity?
Is there a way to lower alkalinity without lowering PH
Will dumping a bunch of water, and refilling the pool help/solve the problem?
What's the best way to proceed here?
All Pool Grade Chemicals:
I use tri-clor chlorine pucks
I have PH+
I have PH-
I have Alka Plus
I have pool clarifier
I have algae clariifer
I have crystal shock
I have PH+
I have PH-
I have Alka Plus
