alkalinity always high
Amydben
3
Texas
Alkalinity always in the high range of 100-120. Other readings always good. PH sometimes is slightly high but not out of range. Usually add 1 gallon MA every 10 -14 days to keep levels around 80. We have 22,000 plaster SWG in south Texas. Any suggestions? Is this normal?
Amydben
3
Texas
This is second year for pool. I use the Taylor testing kit I bought from this site. Waterfall runs couple hours each day. Chlorine remains good at 4-5. Have checked with store bought strips to verify kit was okay. Still get same results
IceShadow
2,529
Milwaukee, WI
Do you add fill water for evaporation? What is the TA of your fill water?
pjt
333
The Woodlands, TX
Pentair Intellichlor IC-60
Where are you in south Texas? In my part of Houston, the fill water has a TA of 330.
