Algae
rlawlor
8
Hodgdon,Maine
Help!! I have a salt water pool. When I brush bottom of pool you can see yellowish stuff move across the floor of pool. Read it was yellow mustard algae. I’ve done the green to blue,and vacuumed to waste. Water is cloudy what should I do now? Any info would be great.
rlawlor
8
Hodgdon,Maine
Had the pool since 2013. This is the first year we are doing the maintenance ourselves . We had an algae I used green to blue with the flocculant. I vacuumed out to waste. A brown powered substance was still in shallow end. I stirred it up and I then shocked my pool. Deep end is crystal clear. But shallow end will not clear up. Salt level 2342/ PH 7.5/ TA 120/ TH 200/ CYA 60 attached picture.
