Air bubbles
mknauss
22,404
Laughlin, NV
First try cleaning and lubricating the pump basket seal. That is easier than a full seal kit between the motor and pump.
coachhim
75
Oklahoma City, OK
Should have put that I did that already. I am thinking i can see small air bubbles while the pump is running within pump basket near the lid. There is a sign that says, the o-ring is prelubricated and not to add lube. I read that after I lubed it of course.
pooldv
Platinum Supporter
25,408
FL panhandle
I can't really see any bubbles in the pics. But, it is normal to have some air bubbles in the pump basket. If the amount of air in the pump basket remains constant then it is ok. If the water level continuously drops in the basket while the pump is running and the pump loses prime then you have a suction side leak.
Is this a saltwater pool with a saltwater chlorine generator? As mentioned previously the bubbles you describe coming from the returns sounds like bubbles from an SWG cell.
More here, Suction Side Air Leaks - Trouble Free Pool
coachhim
75
Oklahoma City, OK
It's a chlorine pool not salt water. Not losing any water in the basket. Just small bubbles coming from return jets. Im wondering if i have an underground leak? Just don't know where the leak could be coming from
mas985
12,782
Pleasanton, CA
I don't see much in the way of bubbles in the pump basket either so I don't think that is causing bubbles to come out of the returns. Do you have solar (on the roof) and is it currently running?
