Air Blower plumbing
wmmallette
184
New Albany, Mississippi
In addition to my regular wall returns, I have 4 returns at my steps. 0me On each side of the steps and two returns on the front of my middle steps. I have an air blower that injects air to the step returns. However my installer only ran one air line that spilts to the four step returns near the pool. I didn’t realize it until it was under concrete.
I had intended that he split the air line near the blower and put it 0n valves so that I could choose to isolate the air to either the step side returns or the step front returns. So, my question is:
Can I now cut the current air line, split it how I want, put valves in and connect it to the return lines near the equipment pad?
Its about 30 feet from the pad to the steps. My water lines are 2-inch pioe. This is my air blower.
Any advice is appreciate, even if it’s that I cannot accomplish my goa this way.
-Mickey
mas985
15,161
Pleasanton, CA
No, you can't do that. The air line connects to a venturi tee in the pool wall like this:
The only way to do what you want is to remove the concrete where the air line is split.
