in attached pic, i've added a finger pointing at what i think is the air bleed. Correct? I've never used it until today, and i'm just not clear on the concept. i expected some air to come out of the little hole, because i definitely have a suction side air leak, but it immediately looked like all that came out was plain unbubbly water., so i closed it after about 10 seconds. Should i run it longer? It is not at the highest point of where water is moving through the valve, so i wonder if there might be air trapped above it. Thanks
