- May 8, 2020
- 163
- Vinyl
- Liquid Chlorine
- Hayward Salt & Swim 3C
Hello All,
Haven't been on TFP since last season, as our Canadian Prairie winters aren't too conducive to outdoor pools for some reason...
I first found out about TFP in 2019 or 2020. Used the TFP method in 2020 and loved it. Added a salt cell for 2021 and had even less chemicals to handle - awesome!
Here's my question: How important is the TA and pH and Muriatic Acid monitoring/correcting in an above ground pool that is only open for 4-5 months and then drained?
Background:
Our well water here on the farm has very high TA and pH. I haven't filled yet this spring because we are still covered in the white stuff (thanks Colorado!) but the past couple years, the first test of the spring typically shows TA in the 450-550 range.
In 2021, I would wait for pH to climb up to the 7.8-8.0 range and add acid to push it back down to 7.0-7.2. Repeat. Repeat. Repeat. TA would slowly be dropping. In the beginning, it would take 3L of acid every 3 days. Towards the end of summer, once TA had dropped lower, it was closer to 1L every 4 days. Always waiting for the pH to rise and then using acid to push it lower. However, by end of summer, TA was still 150. At this point, Ma Nature does what she always does, and I had to drain the pool for winter. (I leave 6-8 inches in the bottom so it doesn't blow around, and so the chlorine puck floater can move around now that the pump can no longer run, but basically empty.)
Now I see that MA price locally has jumped 33% compared to last year.
My point is - given the starting point of the water, I am never going to get TA down to the 50-80 range anyway.
How important is it to try to correct pH and TA?
Or can I simply let the salt cell do it's thing with chlorine?
Remember - the water is only here 4-5 months. (I already had the pool full this time last year - this year will likely be closer to 4 months.)
Thoughts?
Andrew
Background:
Thoughts?
Andrew
