I am needing some assistance on how to remove the center caps from my pool so I can get the top rails off as the liner is in need of replacement. The center cap is held loosely in place with one screw and the underneath of this screw is held in by a square nut. When I try to remove it, it simply just spins. Any thoughts as if anyone else has seen or ran into this issue? I'm unsure of the pool manufacturer but I would say its atleast 20 years old. An "MB" label is on the other side of the center cap (the piece that is removed from the pic).
I've attached some pictures to hopefully assist with this.
Brandon
Brandon
