Different kind of problem and I wanted to see if anyone has experience in this and/or any thoughts.
Background info:
We have a Doughboy steel frame AGP, which has a deep end going 4 ft. below grade at the far end. Our sewer line goes from the house through the BACK of the yard into the city sewer line, possibly very near or even under the pool. The sewer line is deteriorating and possibly ready to collapse in the foreseeable future. This was noted by video camera inspection.
We've been given several estimates and each uses a different repair method. One wants to dig up the yard and replace the line, possibly requiring removal of pool. One wants to reroute the line, digging up the yard but avoiding the pool. One wants to push a liner sleeve thru, not digging up the yard. All 3 would require ripping up the landscape brick patio.
The adirondeck chairs are at the back of the yard near the city sewer line. Our sewer line might be right next to the pool. A gas line runs right down the middle of the open yard area, then takes an angle to right, to the back corner. An electrical line runs from the corner of the garage (approx. 2 ft. back from where you see the red bird in flowerbed) to the right, to the back corner of the yard.
The equipment is in the back corner of the yard.
So my question is in regards to the "reroute" method.
Since the new line would avoid the pool, the old line would remain in place. Could that old line collapse and cause settling of the pool frame, still forcing us to remove the pool and have to re-level it?
Should we consider having the old line filled with something like injected dirt, sand, concrete to prevent the line from collapsing and causing a problem with the pool?
I'll bet you've never been asked this question before.
Background info:
