Aftermarket AGP Wall Coating for Semi In-ground Install
Nathan8372
56
South Texas
Intex Krystal Clear
Good Morning,
I was wondering if anyone was coating their above ground pool walls with anything prior to partially burying them. I received my HII resin-frame pool with steel walls and was looking for input on doing this. My soil is a clay-mix so the hole should retain it's shape without concrete slurry. My question is if I should coat the steel walls with tar or truck-bed spray before backfilling. I read something about people putting tar paper against the wall prior to backfilling but I think that would just trap moisture between the pool wall and tar paper. I'm not really concerned about warranty retention.
ajw22
24,940
Northern NJ
Pentair Intellichlor IC-60
