- Oct 17, 2021
- 40
- Vinyl
- Hayward Aqua Rite (T-9)
We recently had our SWG pool started and I am very close to getting water balanced. Current tests (Taylor test kit) results are:
FC: 5.0, pH 7.6, TA 175, CH 300, CYA 50, Salt 3000, BOR 0.
Water is clear. 16.5K Gallon Vinyl pool with hayward sand filter. I plan to add Borates at some point and planning with that end in mind what should I do next.
I have few questions:
1. Does Taylor test kit measure TA or carbonate alkalanity (already accounted for CYA)?
2. I know current TA at 175 is high and need to bring it down to 90. Can I bring it down over the season as I add muriatic acid to lower pH or does group recommend the cycle of lowering pH to 7.2 and aerate to raise pH?
3. Current CYA is at 50 ( I believe it is slightly higher ~55). Should I increase it to 75 but than I have seen recommendation that Borates CYA target is 50 ppm?
4. I plan to use Boric acid (40lbs) to bring pool to 50ppm. Does group recommend adding Borates or not? We have young kids and infants and worried abt toxicity?
Thanks
Ashish
Thanks
Ashish
