Advice on run times SWG adjustment ta
Skiddy
102
Seminole Florida
Pentair iChlor 30
So things are looking good I have been taking as much advice from members as possible and learning a lot. What I have not asked yet is how long I should be running the pump and at what speeds. My chlorine is consistently high so I am wondering if I can either run my pump less or turn down the SWG which is currently set at 50%.
thanks for any advice
ajw22
24,886
Northern NJ
Pentair Intellichlor IC-60
You need to run your pump for the time necessary to generate the FC you need.
You can run your VS pump at whatever speed closes your SWG flow switch + 200 rpm.
Either one gets you to the same point of lower FC production.
Reactions: mknauss and Skiddy
Jimrahbe
21,221
Bedford, TX
S,
Yes, that is the whole point of a SWCG.. You adjust your run time, or cell output, or a combination of the two of them, to match your FC usage..
Reactions: Skiddy
cowboycasey
5,954
Southern OK
I run my SWG at 100% and only turn it on enough to create the chlorine I need.. I run my pump at 800 RPM 24/7 unless the SWG is running and that runs at 1500 rpm for 2 hours right now..
some run 24/7 and run the SWG at a % to get the chlorine they need..
wireform
In The Industry
Aug 15, 2017
2,115
Spring Valley, NY
Some people run the vs pump 24/7 with the minimum rpm for the SWCG. This way the pool skims all the time and have the SWCG on a timer to control output along with the percentage setting.
Skiddy
102
Seminole Florida
Pentair iChlor 30
Great thanks for the responses. Ill have to take a look at the min. RPM requirements for my SWCG production.
cowboycasey
5,954
Southern OK
it really is easy, just turn your VS pump down to 800 and see if the flow light turn red and go up by 100 rpm. after it turns green add 200 rpm to it and that is your min setting :)
Reactions: Skiddy
Skiddy
102
Seminole Florida
Pentair iChlor 30
That was a nice little experiment. It turns red under 700 so I bumped it up to 900. Im going to try running it 10 hrs a day 6 hrs at 900 and 4 at 1600 and keep a close eye on chemistry.
Skiddy
102
Seminole Florida
Pentair iChlor 30
So just when I thought I was starting to understand things a little better I came across another thing I dont quite understand. The pump should have been off for the day but it was running. When I looked at the app it says running under "pump override". I see that there is a override for the Ichlor and for the Heat pump. I dont seem to have much control of these settings other than pump speed. Can someone explain these too me?
Jimrahbe
21,221
Bedford, TX
S,
I don't have any experience with the IntelliConnect, but assume you either have something else running that requires the main pump to run, like a Cleaner, or you manually turned the pump on. Not sure on the IntelliConnect, but with an EasyTouch if something is scheduled and you turn it on manually it can run for 12 hours because the schedule gets our of sync.
Just a guess on my part..
Reactions: Skiddy
