Advice on Calcium Hardness
dpdeleon
26
NJ
My calcium hardness is at 240 but I've noticed websites suggesting that CH should be 175 - 225 although TFP is suggesting an ideal range of 350 - 500 which is much higher. Why would there be such a difference, what number should I use (I don't want to exchange water if its too high), and what is the target number for most of you? Thanks.
ajw22
28,635
Northern NJ
Pentair Intellichlor IC-60
TFP calcium recommendations are made looking not just at the CH requirements of your plaster but also at the overall water balance as measured by the Calcium Scaling Index - CSI. We have found a higher CH level provides the needed balance .
You need to use PoolMath to calculate your CSI and see if your CH level works for your water chemistry.
