Adjusting PH while SLAMing
JibJab
24
Fort Worth, TX
I began the process of SLAMing the pool yesterday, starting with a 7.4 ph. This morning, I'm testing at 7.7, presumably because of all the 12.5% liquid bleach I added. Should I add muriatic acid now, or wait until SLAMing is done? If so, how long should I wait after adding the acid to add the chlorine?
jseyfert3
672
South-Central WI
The pH test is not accurate when the FC is above 10 ppm. Do not act on any pH test result taken when the FC is above 10 ppm.
Wait for the SLAM to finish, allow the FC to drop below 10, and retest the pH before adding any acid.
P.S. adding liquid chlorine does not change the pH of your pool.
JibJab
24
Fort Worth, TX
Ok... I guess I'm just scratching my head a little, because using pool math, I added enough chlorine to raise my FC to 20, and this morning it is testing at 5, which makes me think it may be higher?
But, I have done nothing but brush the pool and add chlorine, so I'll have to go with your assessment and ignore the pH for now.
HeyEng
434
Oklahoma City, OK
How much time was there between adding chlorine and the test? If it's been a while then the organic material in the pool is probably eating up the chlorine. How are you testing your water?
JibJab
24
Fort Worth, TX
I put the chlorine in last night, and then just tested it now, so about 12 hours. In retrospect, I should have tested a few hours after my last dose last night. So I don't doubt that the FC is now at 5. And this leads me back to my original thought of adding acid.
Richard320
22,688
San Dimas, CA (LA County)
If the FC is 5 then the pH test is accurate and if you absolutely feel you must, you can add acid. Wait at least fifteen minutes after adding it to add the next load of bleach.
