Adding MA every day or get a dosing pump.
Woodsy27
Active member
Mar 17, 2020
34
Thailand
Hi,
Ive worked it out that i have to add 14oz of MA every day to keep my PH balanced at the same level. So is it better to buy a dosing pump , so less interaction with the chemical...
Your thoughts please.
Jimrahbe
21,895
Bedford, TX
27,
Where are you trying to keep your pH? My guess is that if you let your pH rest at 7.8, you will use a lot less acid..
I would dose every day for a couple of weeks and see how well it works and how much effort it is. Then you will know the answer
Woodsy27
Active member
Mar 17, 2020
34
Thailand
27,
Hi Jim,
Thanks, i have dosed for the last 2 weeks....i get it down to 7.2, then everyday it rises 0.2. Today it was at 8.0 so added 25oz of MA, now 7.4.
The reason i think i need a 'dosing pump' as I will not be home all the time, sometimes away fo 4-5-6 months and dont really want the family to do handling the Acid.
Thanks for your feedback
27
wogster
In The Industry
Apr 30, 2018
160
Toronto, Ontario, Canada
Your TA is the problem. The pool industry recommends 80-120 for Alkalinity, this is so they can keep selling you acid and buffer. For a home pool, that does not use an ORP sensor, you can let it drop to about 50, and that will usually mean a lot less pH movement.
Another thing that causes the pH to vary, if your pool has, water features, running them can increase pH through aeration.
Woodsy27
Active member
Mar 17, 2020
34
Thailand
Hi thank you.
Now for about 2 weeks I have let PH go to 8.0 then add Acid to reduce to 7.2, but TA is still not reducing..following TFP suggestion.Although I know it can take time.. The problem is I will be leaving the pool soon and leaving it to family to take care... So I want to make it as easy as possible for them.. ( not adding MCmanually)...
Woodsy27
Active member
Mar 17, 2020
34
Thailand
Hi all,
now my PH only rises 0.1 per day (hope it stays that way), so im thinking my TA has been lowered, using the system TFP suggested thanks.
setsailsoon
3,918
Stuart/FL
CircuPool RJ-30 Plus
Wood,
I had similar issues initially. I was able to reduce acid consumption and frequency with 3 changes:
  • reduced run time for spill-over (reduces aeration which causes pH to climb).
  • added borate buffer.
  • operate in the high end of the TFP pH range while keeping a close eye on the CSI calculation in Pool Math. Staying slightly negative and never outside TFP recommended range. This seems to be working well for my swg cell. After one year of operation the cell has never been cleaned and looks brand new. Maintained 40% power since installation.
I never had to add acid daily but it was almost every other day. Now it's usually once per week.
I hope this is helpful.
Chris
atccf
37
Winchester, VA
Wood,
Chris
What are borate buffers?
setsailsoon
3,918
Stuart/FL
You can improve pH control with addition of boric acid or borate compounds. There are many other less tangible benefits but I can't say I've experienced them. Please read more here and let us know if you're interested and have any questions.
Chris
Reactions: atccf
atccf
37
Winchester, VA
Chris
Thanks Chris. I’m going to research this. We have dogs that get in the pool quite alot so that is another consideration.
setsailsoon
3,918
Stuart/FL
at,
Pets are definitely and issue you need to look into. We don't have any at this time and seems there's contradictory information so if I had a pet I'd check thoroughly to be absolutely certain before doing this.
Chris
Reactions: atccf
