Hi there.
I have CYA in the sock in front of the return and have new set of cartridge filters waiting to be installed. How long should I wait before replacing cartridges? Pool water chemistry says "not backwash/clean the filter for a week", does the same recommendation apply to cartridge replacement?
Also, I could be wrong but I believe squeezing the sock was not really recommended a few years back and I believe it used to say CYA will take a week to register, now it says it can be tested after 24 hours.
I use two socks (one inside another, no holes), is it ok to squeeze it all out within a few minutes and be done with it? Will CYA reading be accurate 24 hours later or should I wait longer?
My chlorine usage seems to be a little high, although overnight loss is 1ppm. My testing shows 30ppm, leslie's 40, but I lose 5-5.5ppm during sunny day. I aim at 40ppm, it worked best for me in the past and now it's recommended.
thanks
thanks
