So we finally got electric (extension cord) to our pump/filter (electrician is coming tomorrow) and added the stabilizer tonight along with another gallon of liquid chlorine (it is basically gone the next day with 0 CYA). My husband diluted 2.5 pounds of stabilizer, dumped it in the skimmer and ran the pump on high 7hrs. I see it is recommended to run the pump 24hrs or until the stuff has fully dissolved. Because he did it the skimmer way I can only assume it is mostly dissolved, as I no longer see granuals in the pump filter. Do I have to run the pump power on high or can I run it on low for the 24hrs? And it looks like I need to wait 4-7days to see the levels on the tests. If I test 24hrs later and the chlorine is 0 again, should I keep dumping in liquid chlorine each day until the CYA shows up on tests? I cannot wait to get the SWG up and running!
