I tested the water after the rainy season we had here in California and CYA showed 0. Repeated the test at Leslie's and result was also 0 . Pool is about 34000 gal so the recommended amount to add is 19 lb to reach 70 ppm. Already added the 19 lb, last scoop today, and reading is off the charts probably 150 using Taylor. Should I freak out or wait ? I read on the Leslie's stuff that I should wait 72 hrs to measure.
