adding calcium to vinyl pool
barryjmizell
14
Poplarville, MS
It is best to add calcium chloride in small batches so you can be sure you get it fully dissolved when you broadcast it in the deep end. Brush well.
Hello there. After purchasing Calcium Chloride to adjust my CH level per the Pool Math app, I have read on here where it is not absolutely necessary to monitor ones CH level in a vinyl lined pool like mine. What are your thoughts on this? Just thought I would do a little research on here before dumping the 13lbs of product to bring my CH from 125 to 175.
Richard320
23,881
San Dimas, CA (LA County)
You mis-read that. You should still monitor your CH, in case it goes high on you. You might need to shift pH or TA or replace some water to prevent scaling.
gorocket1981
159
Montreal, Canada
I have a vinyl liner but I also have an heat pump. I have been told that it was important to maintain calcium at 200+ to prevent damage to metal inside the heat pump. Does this make sense? Is it real?
mknauss
31,166
Laughlin, NV
No. But the manufacturers still follow the old boiler standard.
If you want to strictly follow their standards, add calcium. Won’t hurt anything.
Reactions: inatae
