Moved from here ..https://www.troublefreepool.com/threads/howto-add-more-than-2-valves-to-easytouch-4-8-panel.151896/post-1344552
Guys,
I have a related question. I’m adding a makeup water integration and was looking to use a smaller valve actuator as I will use a 3/4” pipe connected to the hose bib. I was thinking of using a 24V sprinkler valve for that. It comes with two wires for power/control. Any suggestions on how to integrate it? If I’m going the relay and transformer option, it will apply 24V to the actuator for as long as relay is open, any issue with that? Should the power be added only for the duration of actuating or is continues power ok?
Guys,
