Sooo I’ve read about putting stabilizer in a sock in front of a return jet to help dissolve. I’ve also read that it takes hours for it to dissolve.
I recently bout some Clorox stabilizer and put 4 pounds in a skimmer sock (thinking this would be the same type material as panty hose). I hung the skimmer sock in front of a return and bumped my pump up to 3400 rpm’s. I set a timer for 20 minutes, to then go out and try squeezing the sock.
After 20 minutes, I came back and noticed white granules lining the bottom of my pool wall, opposite from the return jet I set up the stabilizer in. I looked at the sock and granules (real fine) were flowing pretty good through the sock. I squeezed the sock and everything came out super easy. I was done squeezing in about 5 minutes. After, I noticed lots of fine stabilizer dust in the pool. I grabbed my brush and brushed as much as I could, along with rubbing my dolphin.
My question is, are skimmer socks a bad idea to use? This seemed way too easy from what I’ve read. Is the material too thin to allow stabilizer to dissolve? I’m just worried I may stain the plaster if I didn’t get everything.
