Added Chlorine Shock and Muriatic acid to Cloudy Pool, FC still 0.6
giant_donut
51
Austin, TX
Quick update:
Passed OCLT!!
Last night tested at 9:30pm
FC 24ppm
CC 0.5ppm
This morning tested at 7:45am
FC 24ppm
CC 0.5ppm
Water is clear!
Thank you for everyone's help! 4 days of SLAM is over :)
Reactions: magiteck
geh
99
New Orleans
One way to spend your pool service savings is on a robot. Bought mine a year ago based on recommendations here and never looked back.
Agreed. I had a Polaris 280. It did a terrible job. I replaced every part more than once. I was hesitant to get a robot because I had the plumbing and pump for a Polaris so why abandon that? I got a Pentair Warrior SI (you can get a Pentair Warrior SE out the door for $600), and it does a much, much better job. Along with your new mastery of your pool water, you won't look back. I am keeping my Polaris for parts for my neighbor's Polaris repairs. That's its only good use. Meanwhile, you are going to have to manually vacuum those nagging dirt collecting spots regularly.
Reactions: giant_donut
Casey
11,922
SW PA
Fiberglass
Jandy Aquapure 1400
Quick update:
Passed OCLT!!
FC 24ppm
CC 0.5ppm
FC 24ppm
CC 0.5ppm
Water is clear!
Now... make sure when you drift down to your target FC/CYA that you continue to feed your pool and don't drop below the target range. Once you do, you invite algae.
kellyfair
4,299
Tampa, FL
Intex Krystal Clear
