Added 11 jugs Clorox Concentrate and FC still at 1.5 ppm
Emptied 2/3 and refilled. Now down to 55 CYA. Wish me luck!
Pool store this morning told me that 'adjusted' TA is what we should be looking at, which is function of TA and CYA. Is this true? Pool math and the recommended levels table both just state TA.
JasonLion has this summed up very nicely in this post, http://www.troublefreepool.com/threads/8141-The-1-3-Rule. His answer is about the 8th response.
That adjusted TA thing is completely wrong. You want to use TA straight from the test kit. Adjusted TA is only ever used when calculating LSI, and there is essentially no reason to ever do that any more (LSI has been replaced by CSI, and CSI uses TA from the test kit).
Good Luck!
No - just CYA. The pool store doesn't understand (normal).
