Actually, since you just moved in, you may not know the entire chlorination history of the pool.
But if the tab feeder is full, that's what they used before. So here's some more info:
1. Acid wash? Yes, it does strip some plaster off and reduces the life expectancy. Do you know how old the pool is? Does the surface look solid or worn? Calcium streaks or stains? If you don't "have" to drain it, I probably wouldn't, but sometimes you have no choice.
2. At the same time, you do have to lower the CYA, and the only way to do that is by exchanging some water - probably quite a bit. As an example, if you exchange 50% of your water, it should lower the CYA by 50%.
3. Once you lower the CYA to something between 40-60 (ideally for now), then we would evaluate if you have algae (cloudiness, spotting, green, etc). If you do, then a
SLAM Process would be in order. If the water looks
crystal clear and you do not suspect algae visually, you could do an
Overnight Chlorine Loss Test as a tool to confirm.
Does that help you with your options or concerns?
