Hello! A couple of years ago I purchased a home with a pool that had significant staining. Last year I had the pool drained and acid washed; staining was greatly reduced but there’s still some residual. I’d like to do an absorbing acid treatment and then drain the pool again (I don’t want to have to deal with sequestering agents). It’s the beginning of the season here so I just pulled off the pool cover today and opened the pool. I’ve brushed and vacuumed the pool and brought the pH down to 7.2. I haven’t slammed or added any chlorine so the water isn’t clear. Do I need to get the water clear before treating? I’m guessing I don’t since the absorbing acid will eat the chlorine anyway but wanted to check with the pros here. FWIW, water temp is 52.
Thanks for any advice and pointers!
