Above Ground Solar Heater Panels
Jun 12, 2017
4
Highland Park, NJ
I no longer have full sun as my backyard trees have gotten tall and full (hubby refuses to cut them down!). Have a solar blanket which I keep on except when swimming but it is not enough anymore - too many days when water needs to be a bit warmer to enjoy. Jumping into the solar heating panel "pool". My house gets full sun so plan on mounting them on roof which is 1 story up (pump is about 15' from house). I have an Intex Ultra Frame 12 x 24' x 52" and 14" sand filter/pump with a Hayward through the wall skimmer. No hard plumbing (pvc) - just regular hoses.
A few questions:
  1. Can my system handle Doheny's 5' X 20' ( two 2.5' x 20') solar heat collectors? Is is overkill (I'd prefer a bit warmer than cooler)?
  2. Since it is going on the roof, will my pump be strong enough to push enough water through to make a difference?
  3. What plumbing modifications do I need to make? If I am understanding the connections correctly, every time I turn on my filter, water will go through the solar heater... is that necessary?
Thanks.
Reactions: denwood
1poolman1
In The Industry
Jul 14, 2014
4,082
Sacramento
A few questions:
Thanks.
Neither an Intex, nor any other above ground pool pump, would likely be able to push water to a roof and through solar panels. You would also nee a 3-way valve to divert water to the solar when heat is available and away when it is not and a check valve in the return from solar along with a T in the return line to the pool.
Reactions: denwood and Mrs LBH
denwood
52
Northern Ontario, Canada
Your intex pump (that ships with a 12x24) should manage 2 panels no problem to a 15’ head. Like @1poolman1 advises, you’ll want a 3 way valve, but it’s also a good idea to install a vacuum breaker on the supply side…just before the panel input will work ok.
I would advise though starting with 144 square feet (4 panels is a good start) at minimum as 2 won’t do much. 4 panels in full sun (assuming they are 2’x20’ panels) will max out at about 50K BTU in noon sun, and warm your pool (8400 gallons) 1 degree F in just under 90 minutes. You’ll want a solar cover as well to keep those BTUs in your pool :)
