Hi dear trouble free pool members,
I set up the Bestway 22x12x48 pool, FlowClear 1000 Sand filter and filled it with tap water. Took the water sample to local Leslie's.
First day results: Date: 07/24/20, pH 8, Alkalinity 110, Cyanuric Acid 30, Free Chlorine 0, Total Chlorine 0, Phosphates 0, Calcium 200, Iron 0, Copper 0
They told me to add 13 oz Leslie's Dry Acid and run the filter 4 hr. Wait to see if PH is good, Add 5 oz Leslie's Chlor Brite and run 4 hr.
I added these and run the filter all night.
Today's result: 07/25/20, pH 7.4, Alkalinity 120, Cyanuric Acid 30, Free Chlorine 2, Total Chlorine 2 (correction), Phosphates 0, Calcium 200, Iron 0, Copper 0, TDS 200
She said it is perfect and we can go in swimming and I need to run the filter at least 4 hours and while people are swimming in it. She said to go back on Tuesday so she can test and show how to work the strips. I asked if I should add anything else, she said not till Tuesday. I asked again "Wasn't I suppose to add chlorine every day?" She said "nope".
Questions:
1- Is it safe to run the filter while swimming?
2- Aren't I supposed to add chlorine everyday?
3- I purchased vacuum and brush. Will brush everyday and vacuum every week.
4- What else should I know? What is a good routine?
Best Regards,
Questions:
Best Regards,
