above ground pool foundation thermo barrier sheets & adhesive
Getting above ground pool. Built 9' x 14' concrete slab.
What kind of thermos vapor insulating floor barrier sheet do you recommend?
What kind of adhesive do you recommend? Should we get hardwood flooring adhesive? Urethane flooring adhesive?
Thank you.
We are thinking of these, what would you choose?
1. 100sqft (2ft Wide) of NASA TECH Commercial Grade Solid White Non Perforated Platinum No Tear Green Energy Radiant Barrier Reflective Insulation Solar Attic Foil Roof Attic House Wrap SCIF RIFD - - Amazon.com 100sqft (2ft Wide) of NASA TECH Commercial Grade Solid White Non Perforated Platinum No Tear Green Energy Radiant Barrier Reflective Insulation Solar Attic Foil Roof Attic House Wrap SCIF RIFD
2. https://www.amazon.com/gp/product/B000BPAULS/ref=ox_sc_act_title_2?smid=A2Q1LRYTXHYQ2K&psc=1 Reflectix BP48010 Double Pack Insulation, 48 in. x 10 ft
3. 250sqft (4ft Wide) of NASA TECH Commercial Grade Solid Platinum Non Perforated No Tear Green Energy Radiant Barrier Reflective Insulation Solar Attic Foil Roof Attic House Wrap SCIF RIFD - - Amazon.com 250sqft (4ft Wide) of NASA TECH Commercial Grade Solid Platinum Non Perforated No Tear Green Energy Radiant Barrier Reflective Insulation Solar Attic Foil Roof Attic House Wrap SCIF RIFD
4. Roberts 120 sq. ft. 10 ft. x 12 ft. x 0.006 in. Roll of 6 mil Moisture Barricade Polyethylene Underlay Film-70-115 - The Home Depot 120 sq. ft. 10 ft. x 12 ft. x 0.006 in. Roll of 6 mil Moisture Barricade Polyethylene Underlay Film
5. Roberts AirGuard 100 sq. ft. 40 in. x 30 ft. x 2 mm 5-in-1 Underlayment with Microban for Laminate and Engineered Wood Floors-70-105 - The Home Depot AirGuard 100 sq. ft. 40 in. x 30 ft. x 2 mm 5-in-1 Underlayment with Microban for Laminate and Engineered Wood Floors
