We just switched from an intex metal frame to a metal wall above ground and started to fill with water this evening.
1. We had our yard graded last month, all sod removed, laser leveled, and replanted, leaving a circumference that matched the pool.
2. We had about 2” of sand brought in for the bottom.
3. We dug in patio blocks for the 14 uprights and made sure each block was level front to back and side to side.
4.We also dug in 2 extra patio blocks per span, so basically the entire track is resting on dug in patio blocks that were leveled. We had debated doing a concrete pad, but didn’t know if the next owners would want the pool when we sell, but we liked the added reinforcement of having the track set on the blocks.
5. Pool wall went together ok, we checked we were in round, all the top rails and such went together as expected.
6. started to fill the pool with enough water to work out liner kinks this evening and we looked a bit off. I did a quick measurement and at two of the posts I had 36” between waterline and top rail. These two posts are across from each other. I moved on to 2 posts going the other direction across from one another and I had 35 and 36 3/4” from waterline to top rail. So if going clockwise, it went 35, 36, 36 3/4, 36 at four opposite points in the circle.
We stopped the water for the night anyway, but I’m wondering where we go from here.
