A Breakdown of Dolphin's 2017 Lineup
thebombardier
In The Industry
Jul 16, 2017
302
Massapequa, NY
#1
There seems to be a lot of confusion surrounding the differences between the pool cleaners Maytronics has to offer this year, with their website not offering much help. Hopefully this thread will clear somethings up.
Active/S Series (These two are effectively identical series other than color)
Active 10/S50 (Designated as Above Ground Cleaners)
- 40 foot non-swivel cable
- 1.5 hour cycle, non-adjustable
- 2 Year limited warranty. First year motor, cable and power supply are covered. Second year only the plastic shell is covered.
- Mesh filter basket with non-removable panels
- Will clean floor
Active 20/S200
- 60 foot non-swivel cable **2018+ MODELS HAVE SWIVEL**
- 2 hour cycle, non-adjustable
- 2 year limited warranty (only motor, cable and power supply covered)
- Filter basket with 2 sets of filter panels, one set of removable fine pleated panels and one set of removable mesh panels (4 panels total in each set)
- Will clean floor, walls, waterline
- No caddy (Available separately)
- Weekly timer (Can set unit to go every day, every 2 days, or every 3 days)
Active 30/S300
- 1 hour "quick clean" cycle or 2 hour regular cycle, adjustable through MyDolphin app or on power supply
- 2 year limited warranty (first year bumper to bumper, second year only motor, cable and power supply)
- Filter basket with one set of removable fine pleated filter panels, optional mesh basket inner liner
- Will clean floor, walls, waterline.
- Caddy included
- Directional remote, accessible in MyDolphin app
Active 30i/S300i
- 1 hour "quick clean" cycle, 1.5 hour short cycle, 2 hour regular cycle, 2.5 hour extended cycle, adjustable through MyDolphin app or on power supply
- 2 year full warranty (bumper to bumper)
- Caddy included
- Cycle parameters adjustable through MyDolphin app (tell unit to just clean floor, just waterline, etc.)
M Series
M200
- 60 foot swivel cable
- 2 hour regular cycle, non-adjustable
- 2 dual panel filter cartridges with one set of mesh removable filter panels and one set of removable fine pleated filter panels (4 panels total in each set)
- Will clean floor and basin (will not go to waterline)
- No caddy (available separately)
- Weekly timer
- Single drive motor
M400
- 1 hour "quick clean" cycle, 2.5 hour regular cycle, adjustable through MyDolphin app
- 3 year full warranty
- Caddy included
- Weekly timer
- Dual drive motor (can make 90 degree turns)
- Third active brush on bottom (aids navigation over main drains as well as adds scrubbing power)
- Directional remote through MyDolphin app
M500
- 1.5 hour "quick clean" cycle, 2.5 hour regular cycle, 3.5 hour extended cycle, adjustable through MyDolphin app
- Caddy included
- Weekly timer
DX Series
DX 3
- 50 foot swivel cable
- 3 hour cycle time, non-adjustable
- 18 month full warranty
- Bottom loading filter bag
- No Caddy
- Weekly timer
- Single Drive motor
DX 4
- 1 hour "quick clean" cycle, 3 hour regular cycle, adjustable on power supply
- Will clean floor, wall, waterline
- No caddy
- Weekly Timer
- Dual Drive motor (can make 90 degree turns)
DX 6
- 1 hour "quick clean" cycle, 3 hour regular cycle, 4 hour extended cycle, adjustable on power supply
- Caddy included
- Weekly Timer
Apollo Series
Atlantis
- Bottom loading small filter cartridges
- No Caddy
- Weekly timer
Apollo
- 3 hour regular cycle
- Bottom loading large cartridges
- Caddy included
- Weekly Timer
- Directional Remote available separately
Apollo Plus
- 2 hour "quick clean" cycle, 3 hour regular cycle, 4 hour extended cycle, adjustable through remote
- Caddy included
- Weekly Timer
- Remote included
JoyfulNoise
Platinum Supporter
May 23, 2015
14,500
#3
An excellent post! This will be referenced.
Of course, the way Dolphin works, you'll be updating it every year as they seem to not be able to not adjust their product line every season 🤣
thebombardier
In The Industry
Jul 16, 2017
302
Massapequa, NY
#4
Eh, it usually doesn't change too much. The real hassle would be an Aquabot breakdown. Though in all reality it would be something like "None of these are reliable enough to be worth buying."
Vinoteck
1
Los Angeles
#6
Excellent job. Now which one to buy. 30,000 gallon in ground pool - re plastered in March 2017 - all new filler, heater THE WORKS !!!!! never owner a robot before always the zodiac sweeper type. Willing to spend good money for the right one. I get a lot of maple leaves in the pool in the fall here in Southern Cali. Any advice. Thanks.
grywlfbg
Active member
Jun 26, 2017
31
NE Oklahoma
#9
Do you have any shallow ledges? With that size pool I'd lean towards the M400/M500. If you're a geek/nerd and want to use the app all the time to tweak things get the M500. If you're not then get the M400.
ride525
316
Pleasanton, CA
#10
For the 30i, and 300i, you list:
1 hour "quick clean" cycle, 2 hour regular cycle, 2.5 hour extended cycle, adjustable through MyDolphin app or on power supply
Don't the specs list 1.5 hour, 2 hour, 2.5 hour? I like the idea of a 1 hour quick clean mode, but I'm confused by what the specs say.
waterl0gged
128
Central PA
#12
Just to confuse things a little .............
I just purchased an S300 this spring and here are some differences than whats in the breakdown above .
The My Dolphin app / bluetooth feature can NOT select any cleaning cycles or weekly timer option on the 300. Those options are only changeable via the power supply. The ONLY thing you can use on the My Dolphin for the robot features, is the remote control option . The owners manual is also on the app , but as far as controlling anything on the S300 via the My Dolphin app , the remote control is it.
Also, my 300 came with the removable pleated "fine" filter inserts , AND the drop in "coarse" filter basket . I think the S300i does as well . I am pretty sure the pleated fine filter inserts and mesh basket inner liner (coarse filter basket) is standard on the 300, 300i .
Also, some models have the extra rotating brush (2 instead of 1) , where others dont. a10,10e, S50,S100 do not, and most of the others from 200 and up do .
Just an FYI, from what I am seeing on my S300.
Geebot
694
#13
The original app for the S300/S300i did allow for remote on/off, selecting cleaning cycles and the timer on the S300 but Maytronics issued an update to eliminate those options and differentiate it from the S300i.
Holydoc
258
Navarre/FL
#14
It's actually 1, 1.5, 2, and 2.5 hours.
The Nautilus is more or less a single drive motor DX-6 without a handle. The Nautilus Plus is mechanically the same as as an M200. Warranties vary.
Hmm... reading the descriptions above, I would say the Nautilus Plus is the M200 with the ability to clean the waterline. Very confusing for one company to have so many similar products. ;)
waterl0gged
128
Central PA
#15
Looks like Maytronics / Dolphin has just further complicated things .
Unless I missed it somehow, but I never remember seeing this new model ...........
http://dolphinpoolrobot.com/en/residential-pool-cleaners/z-series
Now they have a "Z" series .
Looks identical to the S, and active models, even looks to be about the same color combo as the Active .
Models are
Zfun
Z1B
Z2C
Z3i
Just one more model designation, exactly the same as the others , to confuse us even more !
Well, that answers that then !
grywlfbg
Active member
Jun 26, 2017
31
NE Oklahoma
#16
The Z models are the ones for online/internet sales. It's like going to a mattress store. They can say that they'll match prices but the manufacturer changes the model names for each sales channel so it's not the same model and so they don't have to match the price.
bmoreswim
Platinum Supporter
4,309
Central MD
#17
They've officially outdone themselves! This version is smiling at you. I'm sure on the next iteration they will just go ahead and put full faces on them. CraZ.
thebombardier
In The Industry
Jul 16, 2017
302
Massapequa, NY
#18
Pretty much hit the nail on the head. I can get both the Active and S series at my store, but I can only get the Active from one supplier and the S series from another. Neither carries both.
ride525
316
Pleasanton, CA
#19
Margaret of Marina Pool and Spa told me today that Active and S series are for different areas of the country. Since she is in Colorado, Marina Pool can buy from either distributor.
thebombardier
In The Industry
Jul 16, 2017
302
Massapequa, NY
#20
I'm in New York and can get both. Who I get the S series from is an international distributor, who I get the Active series from is only Eastern seaboard. I suspect the Active series is for smaller regional sellers while the S series is strictly for that one larger seller. Maytronics has made private label units for that distributor before (the Dolphin Pro comes to mind, basically a Diagnostic in white with a 2 hour cycle instead of 3).
